MAF says 310 grams/sec@5800rpm......
My MAF tables are stock so I'm pretty sure I'm actually seeing correct g/s
I'm running a 210º/218º .531/.531 114lsa Vinci Cam with 26º total timing and stock 14.7:1 AFR......
Originally Posted by Yelo
I just saw 328 grams/sec @ 5900rpm a little while ago coming to work.....
I've read a few times that on these trucks if you multiply MAF grams/sec X 1.1 it gets you a pretty close RWHP number.....can anyone back that up ???
mroegrip: If that above calc works out that would put me at around 360ish and you around 440hp at the tires ....do you have a dyno run to compare that too ???
damn...I may finally have to admit that you *might* be faster than me grip
you have to compensate for how much the blower takes back out of that.
Originally Posted by zippy
stock should be alot richer than that at wide open.
Adkoonerstrator
At part throttle 14.68-14.7 is fine but, at wide open throttle 12.5-13:1 is about all you want to go for NA.
My stock LQ9 6.0L has pulled down 38lb/min in stock form. That was a high reading. It routinely will hit 36-37lbs/min though and that is around 5400rpm is I remember correctly
For NA engines I think multiplying the maf lbs/min by 10.5 will give you a close estimate to engine output at the flywheel. It's been a while since I've messed with all that though but, that is what I remember being close.
short of buying a wideband how can I get the AFR at WOT where I want it to be ???
If I use those calculations it looks to be around 430 at the crank and 340ish at the tires....pretty close to the other calculation
Those calculations can't be very accurate. On a nice staedy line on the MAF at 6300rpm I logged 327.79 G/Sec = 360.56 Rwhp
43.26 Lb/min = 454.23 Fwhp
For a peak I found 341.14 G/sec = 375.25 rwhp
45.02 Lb/min = 472.71 Fwhp
The only things I have changed from my dyno pull of 333 rwhp are UD pulley and a different air intake. Oh and my intake air temps were about 40* cooler.
