MAF screen removal when installing cold air intake??
Old 11-07-2007, 05:19 AM
coryhussey's Avatar
Default MAF screen removal when installing cold air intake??
Hey, I have a buddy who works at a GM dealer in my area.I told him that when I put my cold air intake on, I removed the MAF screen. He talked to his GM tech teacher, and he said it wasnt very good for gas mileage.He said you will pick up a few horsepower, but will lose some MPG. Hw true is this. I have had it off since i bought the truck, so i have nothing to compare too. It is a 03 gmc sierra 5.3 2wd. Anyone else's thought on this?????
cor
Old 11-07-2007, 07:11 AM
I work for GM too....and I will tell you that this has been an double sided debate for yeras now. But I can also tell you that in applications like a Corvette or Camaro where the MAF is straight inline with the Throttle Body, removing the screen is not a bad mod. But in a Truck where the MAF is around a corner to the Throttle Body, then it's not a good idea. The MAF screen straightens out the air flow pulses and reduces the turbulance entering the TB.
So to cut it short.......I don't do it to my truck.
Old 11-07-2007, 12:11 PM
RotaryResurrection's Avatar
I did it on my 6.0 denali and it runs pretty much identical one way or another, mpg and hp wise. I still have my stock maf/screen saved, and just bought a spare to modify.
Old 11-07-2007, 12:17 PM
zippy's Avatar
On a completely stock application you will gain some due to the way the timing curve is set up and how rich they are programmed for. Unless you have the pcm calibrated for it though it's not worth it on a modified truck though.
Old 11-07-2007, 08:26 PM
Moderately Differentiated
dewmanshu's Avatar
Man, this should be an automated response when the words MAF and de-screen are entered into the title of a thread.
Old 11-07-2007, 08:28 PM
dirt track racer 81's Avatar
so can the thread be locked now??
Old 11-07-2007, 08:30 PM
TXsilverado's Avatar
nah i think "dont do it" should be the automation. also "search" should be in there too
Old 11-07-2007, 08:31 PM
2nd fastest 5.3 ECSB
trever1t's Avatar
Only works if the Tornado is installed at the same time.
mybad
Old 11-07-2007, 08:38 PM
mybad
this should be the first big horsepower gain mod every one should do
Old 11-07-2007, 08:39 PM
gotta install the tornado in front of the descreened maf that way it gets a good reading
Quick Reply: MAF screen removal when installing cold air intake??
