Magnacharger Radix
Old 06-10-2003, 09:36 PM
blownerator
BlownChevy's Avatar
Default Re: Magnacharger Radix
Beers are on me.....But you will be flying on a cargo jet filled with plastic dog toys!
I think I am going to leave it the way it is for now and just take it easy....
Does anyone have a built tranny? Have you noticed a "whine" with the 5 gear panetary set?
Old 06-10-2003, 09:39 PM
Flyer's Avatar
What size pulley did you get? 14psi .. thats insane!
work in progress: the MagnaCharger is already intercooled, so no need for alky.
Old 06-10-2003, 10:16 PM
With a 3" pulley my Tahoe makes 9 1/2lb of boost as soon as I hit the gas it will peak about 11lb at 6000rpm at the shutoff.What size pulley are you running and is the 14lb of on throttle tip in or peak?14lb of boost is not uncommon for a Ford Lightning running oversized lower and undersized supercharger pulleys.The port location on the radix is at a more effecient rear location instead of the Lightning's top location so more power is made with less boost.
Old 06-10-2003, 11:29 PM
da_gizm0's Avatar
u r nuts....i wish i had that setup on my truck!!!! hope it doesn't blow
#1 if my truck doesn't sell im gonna get a sc for it and i only have about 3750$....whats the best for my budget.
#2 what psi can i run on my stock 5.3 without damage...i plan to retard timing and get it all tuned properly after i sc...i want a low 12's truck
#3 what will break first my tranny or rear end...i have a 4/6 drop and already have a little traction problem....what would break if i ran slicks
Old 06-10-2003, 11:32 PM
blownerator
BlownChevy's Avatar
I pulled the pulley off of a sidemount magnacharger I removed off of a customers truck in trade for a radix.....I am not sure on the pulley size but it appears to be about 1/2 inch smaller than my 3.4 pulley. I looked closer at the gauge and noticed that it makes and instant 12 psi and climbs to 13 at the top of the rpm range....I guess my 14 psi was a little off, but it sure did look like it when I glanced at the gauge while Shitting in my pants! Final descision on boost 12-13.
Old 06-10-2003, 11:39 PM
da_gizm0's Avatar
damn i wish i had 5000 to spend on the radix.....money sux when u dont have it....also hows your tranny holden up with all the power..or have u not realy got on it yet?
Old 06-11-2003, 12:15 AM
Flyer's Avatar
My tranny was the first to start letting go. I had it rebuilt, so all is well there now. The guy who rebuilt it said it was a thousand wonders how I was getting anywhere when it went into OD, and that there was some very obvious damage to the 1st gear stuff and the 1-2 shift stuff to let it slip like hell. My rear end is still holding up with p285/75/16 BFG AT's.
I think I am going to order that 3" pulley that whitt1 is using. I may even go smaller once I redo the valve train from the cam to p/p heads to get my boost back up to ~9 or 10.
Old 06-11-2003, 12:24 AM
blownerator
BlownChevy's Avatar
I have had my trans done, so I hope it holds up! Jet did it about 12 k ago and all is well for now. ONce I put the sicks on and run it at the track, that may all change.
Old 06-11-2003, 12:25 AM
Tech Fanatic
MarineBlue03GMC's Avatar
Damn blownchevy! Very cool about the boost increase! Its great that it starts at 12 but only rises 1 psi. That means you are getting almost your max boost instanstly, thats what a supercharger is all about!
I wonder how long that tranny of yours will last? You said you had like 10K miles on the Jet tranny you have now right? If it holds up much longer I think the Jet tranny is gonna be the way to go! Can't wait to see what kinda power you put down this sunday! Your quarter times should be crazy too!
Old 06-11-2003, 12:28 AM
blownerator
BlownChevy's Avatar
Thanks, I hope so! I may be towing it home next Friday!
Quick Reply: Magnacharger Radix
