map sensor ?
Banned
1 Post
Originally Posted by v8
ok at 4k the map sensor is reading 29 and the maf is reading 15, but by the time you get to 62k map is still reading 29 and the maf is reading 39. is this correct or is the maf not doing its job down low??
I JUST WENT CHECK MINE @ 6619 RPM MAF 271.27 MAP IS @ 96
holy **** zden thats is way to high i would think, your maf should read way higher than the maf but then again on a 6000 hp motor your running there must need it lol
that is mass air flow in lbs/min and the map reading is kpa, the maximum map in our trucks is 105 kpa
17,16,15,14,13,12,11 Drvr
man i must have a weak maf and map sensor. put in new maf and it reads at 5700 37 and the map is going to 14.5. so as far as i know that is right with the map.
what are you reading your tables with zden and randy grabert???
