Mass air meter and silicone conectors what do I use?
I have a new intake and I am now using a 90mm TB, I am wondering if I should steo up to a larger mass air meter? Will a 85mm slp or something of that sort work or should I look for something else? Also where can I get a large enough silicone conector for the 90mm TB? Also if anybody knows where I can buy a 4 1/2 peice os aluminum tubing so I can fab some type of cold air set up. If you would like to see what I have I got pictures here https://www.performancetrucks.net/fo...d.php?t=438952
lingenfelter has a 100mm maf. 4 inches...
http://www.lingenfelter.com/mm5/merc...Category_Code=
search for spectre 4 on summit to find all sorts of 4 inch couplers and aluminum piping. pretty cheap compared to buying something premade i guess.
http://store.summitracing.com/egnsea...5&autoview=sku
alot of guys go to sd, do away with maf and o2 sensors. never have to worry about them going bad. why go spend 300 on a new maf when you can do a sd tune. i like the driveability of sd tune. I have it set to run lean at cruise and get better mileage. Throttle response seems better as well.. just my opinion, im sure someone can prove me wrong tho
