Mass air, Throttle body (worth it or not)
My truck is in my sig. And have a couple of questions about my setup.
Is the stock throttle body and mass air to small for the 6.0? Does the 6.0 have a bigger mass and tb? It does whistle at part throttle and seems to want more air but can't suck it in. I have a custom made 4 inch mandrel bent CAI with 8 in k&n filter. I have a cable driven TB. Does the corvette have a different mass & tb? I want to just change the whole setup to a fast 90mm but don't want to spend that much right now. What do you guys think I should do? And is it worth the trouble to get a 85mm throttle body and a different mass air?
Thanks
Thanks
High on diesel fumes
That's what I'm running. There's some fab work involved to make it work with return style fuel rails and a cable throttle body, since all of the 90mm trucks use ETC. The LS2 truck manifold also doesn't flow much better than a stock one. If he's going to go through the trouble of a manifold swap it would be better worth his time to do either an LS6 manifold or a FAST 90.
noproblems209
08-10-2015 06:57 PM
GreyChevy
07-07-2015 08:57 PM
Gadgetized
07-07-2015 04:40 PM
