Max displacement from 4.8/5.3 block?
Old 07-07-2004, 10:19 AM
MOOBIES Moderator
Scream's Avatar
Default Max displacement from 4.8/5.3 block?
I've been looking at that poor, lonely 4.8 just wasting away on the engine stand and started doing some thinking....
I've done a search, but have found some differing opinions on the matter. I've seen where one person went 0.120-over on the 4.8/5.3 block to the stock LS1 3.899 bore--even to the point of running BIG boost and BIG shots on it, with no problems (as of that post anyway, I think it was RECKLESS?) I'm assuming that the 4" stroker crank will work in the 4.8/5.3 block, which would make for a 382. Is it really safe to go 0.120-over on these blocks?
I mean 0.060-over and the 4" crank would still yield 370 cid, which isn't that bad at all.
Would it really be that much cheaper to start off with a 6.0L block, and get 400+ cubes, than to settle for the limits of the 4.8/5.3 block?
Old 07-07-2004, 11:09 AM
Deckhand's Avatar
or keep the short stroke of a 4.8, run a big bore. and rev the crap outta it
Old 07-07-2004, 01:09 PM
12 Second Club
ThunderZ28's Avatar
Old 07-07-2004, 01:22 PM
MOOBIES Moderator
Scream's Avatar
Interesting thought. 0.120 over w/ the stock 4.8 crank would be 312 cid.
Old 07-07-2004, 01:45 PM
onyxsilverado's Avatar
i'm wondering the same. i saw the conversations about that engine...i'm wondering why more people don't do it if it's safe?
Old 07-07-2004, 02:23 PM
mudz5.3's Avatar
Originally Posted by 01 Thunder
O1 Are you trying to say something??? Did you throw an 8.1 crank in that little 4.8 of yours? j/k before a noob gets a hold of this thread.
Wouldn't it be cheaper to just start out with a 6.0 block? I don't think the high revver would be ideal for our trucks, but thats my .02
Old 07-07-2004, 02:31 PM
MOOBIES Moderator
Scream's Avatar
I guess that's my question--would it be worth the extra $$ to start off with a 6.0 if you already have a 4.8/5.3 block, and if the extra cubes would really be worth the extra money.
Is the 6.0 block inherently better than the 4.8/5.3 other than being able to take a larger bore?
Just "bench-storming" here. Not really looking seriously at doing anything with the motor, just thinking.
Old 07-07-2004, 02:36 PM
mudz5.3's Avatar
Well you know how they say there's no substitute for cubes.
Old 07-07-2004, 02:39 PM
granted. but couldn't you still make a decent motor out of it? i ask because i have a 5.3 sitting on the garage floor collecting dust that i'm starting on, and i'd like to know if it is possible to bore .120 over safely.
Old 07-07-2004, 02:45 PM
10 Second Club
taqwache's Avatar
i have heard of plenty of people that bored it out that much. just get it sonic checked first, just to be safe.
Quick Reply: Max displacement from 4.8/5.3 block?
