max HP you can push with 38.5# injectors????
Use the bottom calculator on this page http://www.fbody.com/calc.htm
It looks like just under 500 horse at 80% duty cycle. Of couse you will need to know for sure what fuel pressure those injectors are rated at vs. what pressure you're actually going to run. Use the rated injector pressure vs. what pressure you're running the injectors at to convert the size with this calculator here http://www.witchhunter.com/injectorcalc1.htm
so I think I am safe (if you would call it that) running a 200 shot. Dry of course. I'll just pull timing and fatten the PE each time I up the jet and keep an eye on the logs.
I am determened to hit a 12.9x in the bus. LOL Might as well try it now while there's a warranty. hehehe
silverstreak07
06-28-2016 06:29 PM
05GMC4.8
08-07-2015 09:55 PM
Mossyoakglock
07-17-2015 08:30 AM
