May have found an alternative to AMW
Old 11-14-2005, 10:37 PM
  #41
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
BOth are nice I dont know though hopefully someone that knows a bit more about this can chime in.
Old 11-14-2005, 10:42 PM
  #42
TURBHOE's Avatar
Originally Posted by w41quad4
We ran a catch can with a steel wool element in the can, but instead of venting the can into the atomosphere we ran a line to a vacuum pump. This pump which happened to be in place of where our distributor would have been on our SBC created a crankcase vacuum at any RPM and was then vented to the atomsphere. So the pump basically took place of using the engines natural vacuum, using a ton of steel wool and a decent sized catch can we never saw any amount of oil being released into the atmosphere on the outlet side of the vac. pump. This was all on NA engines as thats all we could run in our class. This did show very much promise though with our engine and greatly helped any blow by we were getting before hand.
so the steel wool filter worked then?.
nabozny21
10-17-2015 07:47 PM
KleanKustoms
09-30-2015 05:07 PM
DrX
09-29-2015 04:31 AM
dantheman1540
14
09-28-2015 09:22 PM
JoshH
09-28-2015 11:19 AM
Quick Reply: May have found an alternative to AMW
