Methanol Injection
Old 02-24-2005, 12:33 PM
  #31
Weedo's Avatar
Originally Posted by TurboBerserker
Meth gives you octane + cooling, water gives you better cooling.
Running water is safer in terms of fire hazard, but I don't use the meth much on the street anyway (and leave the tank relatively empty).
I was assuming that with an electronic boost controller, you would always run the Methanol. Then, if it ran out or you weren't using it, it would switch back to a lower boost setting (say 6psi with no meth or 10psi with meth)?.?.?
I'm curious as to why you don't run it all the time considering it's pretty cheap and adds a bunch of power?
Another question: does the meth get used up much if you're not boosting much?
Old 02-24-2005, 12:39 PM
  #32
greentahoe's Avatar
Originally Posted by Yellowsierra
The cool thing about the snow performance kit is that for $399.99 you get the varible controler or the plain kit for $299.99. I think this is which kit I'm going with.
lator
Yellow
The plain kit uses a cheap pressure switch that didnt work at all for me. I had to buy the controller just to get it to work. The alkycontrol kit is near the same price and uses braided steel line (so no leaks like I had at EVERY fitting) and a better pump.
Old 02-24-2005, 12:40 PM
  #33
greentahoe's Avatar
You set the meth/ alky to come on a predetermined boost setting. If you dont hit that amount of boost, it doesnt spray.
Old 02-24-2005, 12:41 PM
  #34
Yellowsierra's Avatar
If it where me and I could run 8 psi without KR I would set the alky to come on at 6 psi that way it has alittle lead time to catch up.
Old 02-24-2005, 01:01 PM
  #35
14 Second Truck Club
JERRY2500's Avatar
So it looks like Alky Control is going to be the one to get.
Old 02-24-2005, 01:28 PM
  #36
Weedo's Avatar
Is there something wrong with the kit STS supplies?
Old 02-24-2005, 01:33 PM
  #37
How do I change this text
Wilde Racing's Avatar
It sounds like no one has tried it. Unless its one already mentioned.
Old 02-24-2005, 01:40 PM
  #38
JERRY2500's Avatar
Nothing wrong with it. Just cost more than the alky control. Just trying to save a few pennies so i can put it on some other mod.
  #39
CoonToot's Avatar
Originally Posted by DanaliHD
i have a SMC kit in my truck but don't use it. so far, i can't see that it is worth using. i don't get any more hp or torque by increasing the timing and using the alcohol than i do by keeping the timing lower and not using the alcohol.
On the dyno, I saw a difference without any changes to timing. Look here for some dyno graphs:
Link to FSC thread
Old 02-24-2005, 03:17 PM
  #40
F8L Z71's Avatar
The point of meth inj isn't really running more timing but in running higher boost at the same timing.
Exactly.....
The GN guys really don't add more timing they add more boost instead. They can effectively go from 18-20psi without meth to 24+psi with meth but the timing stays the same in most cases.
Remember that more timing doesn't always equal more HP. Timing is just like it's name, it is timing the valvetrain events and once you pass the point of effieciency with a particular combo adding additional timing doesn't help.At least that's who I've always known it to be.
The STS kit doesn't have the adjustableness of the AlkyControl kit and it's awesome progressive controller. It's a big pain in the *** to wire up but it's a very cool kit. I lik the fact I can easily dial in more meth at the touch of a dash mounted ****. Makes for a more secure feeling on the street if I notice even a tad bit of detonation.
Quick Reply: Methanol Injection
