Methanol Injection
#31
Originally Posted by TurboBerserker
Meth gives you octane + cooling, water gives you better cooling.
Running water is safer in terms of fire hazard, but I don't use the meth much on the street anyway (and leave the tank relatively empty).
I'm curious as to why you don't run it all the time considering it's pretty cheap and adds a bunch of power?
Another question: does the meth get used up much if you're not boosting much?
#32
Originally Posted by Yellowsierra
The cool thing about the snow performance kit is that for $399.99 you get the varible controler or the plain kit for $299.99. I think this is which kit I'm going with.
lator
Yellow
lator
Yellow
#33
#38
14 Second Truck Club
Is there something wrong with the kit STS supplies?
#39
Originally Posted by DanaliHD
i have a SMC kit in my truck but don't use it. so far, i can't see that it is worth using. i don't get any more hp or torque by increasing the timing and using the alcohol than i do by keeping the timing lower and not using the alcohol.
Link to FSC thread
#40
The point of meth inj isn't really running more timing but in running higher boost at the same timing.
The GN guys really don't add more timing they add more boost instead. They can effectively go from 18-20psi without meth to 24+psi with meth but the timing stays the same in most cases.
Remember that more timing doesn't always equal more HP. Timing is just like it's name, it is timing the valvetrain events and once you pass the point of effieciency with a particular combo adding additional timing doesn't help.At least that's who I've always known it to be.
The STS kit doesn't have the adjustableness of the AlkyControl kit and it's awesome progressive controller. It's a big pain in the *** to wire up but it's a very cool kit. I lik the fact I can easily dial in more meth at the touch of a dash mounted ****. Makes for a more secure feeling on the street if I notice even a tad bit of detonation.
