Misfire on #2 at idle
Old 12-12-2009, 10:12 PM
I have a gauge for that
Atomic's Avatar
Default Misfire on #2 at idle
I am getting a bunch of misfires on cylinder #2, but only when I am idling, and only on that cylinder. The misfire count is 800+ and trips the SES light every every few days. I dont get any misfires at cruise and WOT, just idle. Stock plugs and wires have about 50k on them. Should I switch the spark plug with another cylinder and see if it moves, and if it doesn't change, do the same with the wires and coil?
Old 12-12-2009, 10:16 PM
8 Second Club
Flaco's Avatar
i would just install new plugs and wires aswell...cant never go wrong doing a lil tune up
charcold-bowtie's Avatar
Check the wire and plug first. Its too easy.
Thats my thinking^^^, while I was typing
Old 12-12-2009, 10:24 PM
Atomic's Avatar
Already checked them, nice and tight.
Old 12-12-2009, 10:44 PM
03chevyroyce's Avatar
dont just start throwing parts at it
swap the plug and wire with ones from another cylinder first, then work from there
also, check plug gap
Old 12-12-2009, 10:46 PM
Wearin' da big hat
00ChevyScott's Avatar
What color is the plug?
Old 12-12-2009, 10:50 PM
PT's Slowest Truck
budhayes3's Avatar
I'm thinking white porcelain with silver metal...
Old 12-12-2009, 11:00 PM
and a small black cylinder coming out of the white porcelain? lol
Old 12-17-2009, 05:35 PM
Atomic's Avatar
I replace the plugs with TR55s, and stock wires with LS2 wires since I kind of broke one of the wires when I was removing it.... I went with the LS2 wires because they bend 90 degrees at the plug making it easier to keep them away from headers, especially pacesetters.
- Is there a trick to getting to cylinder number 6 plug, because damn that was a pain.
- The stock number 7 plug had a gap of less than 0.02, I say less because my measuring tool wouldnt even fit in there.
- All the stock plugs looked fine, albeit worn, but nothing abnormal.
After I finished I was still getting some idle misfires on #2 so I swapped the coil pack with the one from #6. Now those two works fine and #3 has a slight misfire at idle
Everything works fine at cruise and WOT, just idle is driving me nuts. I check my STIT and they are less than 2% off, so my idle tuning should be fine...
Quick Reply: Misfire on #2 at idle
