Most aggressive tune possible
Old 11-18-2009, 09:23 PM
dirt track racer 81's Avatar
Originally Posted by stranger ranger
60 Second delay?
yep stays at 14.68 at wot for 60 seconds before it goes into pe
Old 11-18-2009, 10:56 PM
PT's Slowest Truck
budhayes3's Avatar
So you have to stay full throttle for a full minute before PE?
Old 11-19-2009, 06:54 AM
yep find you a stock 2500 6.0 tune. when we first started the dyno tuning it took us a while to find that one out. its a 25-30 hp gain too
Old 11-19-2009, 09:35 AM
stranger ranger's Avatar
could someone please explain to me what PE is? I searched and nothing really is helping to explain it.
Old 11-19-2009, 12:20 PM
kbracing96's Avatar
PE= Performance Enrichment. It's what takes your air/fuel from 14.7 down to 12 or so for more power.
I was told GM did the delay in the 6.0 and 8.1 to de-rate them and try to help with fuel mileage.
Old 11-19-2009, 12:33 PM
Resident Retard
BlackGMC's Avatar
also when it does go into PE, the commanded AFR changes and it adds in timing by the way of B5908, IMO that is where the power comes in not from the AFR mixture but from the added timing due to the AFR mixture
Old 11-19-2009, 12:41 PM
Mr. Sandog's Avatar
I thought PE = Power Enrichment?
Old 11-19-2009, 12:47 PM
Resident Retard
BlackGMC's Avatar
it does...
Old 11-20-2009, 10:17 PM
sleeperlqx's Avatar
your most aggressive tune, will have to be very well calibrated, to add the last ounce of timing possible before detonation.. not good for longevity of a engine. i would say atleast 93 or racing octane is required for this calibration. lots of timing with the perfect AFR at all maps etc.. good luck
Old 02-08-2013, 07:53 AM
NegraRCSB2X4auto's Avatar
old but why reinvent the wheels what would be better to run 12.0-12.5 afr and 16 timing or 11.5 afr 18deg? which would give more power no dyno? just want some thoughts.
Quick Reply: Most aggressive tune possible
