Motor/Tranny Swap Under Way!!!
Old 12-15-2006, 04:49 PM
  #21
High on diesel fumes
thunder550's Avatar
I don't think so...My converter bolts were hex head on the outside and allen-head on the inside, you can use both. Are yours different?
I don't think what you are saying will work with holding the crank bolt....when you try to loosen the converter bolts you are going to loosen the crank bolt too. It will work when you put it back in though.
Old 12-15-2006, 04:50 PM
  #22
Tootall's Avatar
Originally Posted by thunder550
Pull the starter, rotate the crank till you can see a bolt in the starter hole, remove it, rotate till you see the next bolt, repeat.....
I have a big open-ended wrench that I put around the converter feet to keep the thing from spinning while I break the bolts loose.
What size are they ?
Old 12-15-2006, 04:51 PM
  #23
thunder550's Avatar
I can't remember off-hand, I'll have to look when I get home. Keep in mind too that I'm running a 4L80E with a 6-bolt Hughes converter, so it may be different.
Old 12-15-2006, 05:16 PM
  #24
14 Second Truck Club
A screwdriver won't work. I don't see where you could put a wrench. I've been stuck trying to figure this out for 2 hours... Does anybody have any pics?
Do you put a wrench through the bellhousing hole? With the 3 bolt converter, mine's not lining up to do it that way.
Old 12-15-2006, 05:32 PM
  #25
thunder550's Avatar
Hmmm I forgot about that, since mine is the 80E I have the big dust cover I can remove and expose the entire bottom side of the converter/flexplate.
Old 12-15-2006, 06:00 PM
  #26
Well ****, I got the first one out and now the second one is starting to strip the hex-hole in the bolt. Any ideas?
Old 12-17-2006, 06:38 PM
  #27
After 2 days of grinding and trying everything possible, I finally fixed the torque converter bolt ground out. Disconnected a few more things and pulled the motor.
(That's my buddy Blake)
That's me by my trophy
Old 12-17-2006, 06:50 PM
  #28
thunder550's Avatar
Sweet, glad you got it figured out!!
Old 12-17-2006, 06:56 PM
  #29
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
Where are oyu located at? IIRC you are in TX somewhere.
Old 12-17-2006, 08:11 PM
  #30
twobit's Avatar
He's from Bossier City La.
Quick Reply: Motor/Tranny Swap Under Way!!!
