Motor/Tranny Swap Under Way!!!
#52
14 Second Truck Club
Got a few things left to put back on the motor, but it's getting there fast. Just waiting on the computer. I just gotta put the intake manifold/injectors, driver side header, alternator bracket, fans, K&N, and a few hoses back on. Everything should be on by tomorrow. I'm really anxious to crank it and see how it sounds and feel the torque!
If you remember, earlier in the engine removal, I stripped one of the stock converter bolts. I ordered some ARP converter bolts...HUGE improvement. They are 13mm and look to be about about 1/4" shorter, but make life so much easier! I put a good amount of red locktite on them as well. Here is a pic:
#53
After 3 weeks today, everything is finally done! I turn the ignition over about 10 times, without cranking it to build up fuel pressure. I tried to crank it about 5 or 6 times and the battery sounded weak. Put the battery charger on for about 30 minutes and it almost turned over. Gonna try it again in another 30 minutes.
#55
formerly 1BADC10 (12/14/2011)
Originally Posted by Tootall
try cranking it over with out the plugs to build oil pressure, then reinstall
GrooveCityZ71
08-31-2015 12:05 PM
superchomper2003
08-26-2015 09:39 AM
iregret
07-27-2015 10:32 PM
