mph shut off
sidenote, but probably not worth mentioning
my D shaft was rusty as hell
so I primed and painted it the
2nd day I had it
I dont see how a rusting driveshaft can get stronger
and Im sure that isnt the main reason they break
but every little bit helps
not to mention how they look in some of the exhaust pics
around here
2nd day I had it
around here
14 Second Truck Club
Driveshafts? this is the first i have heard about that is it the u-joints that are failing or is not balanced good enough or what? Kinda scares me a little bit now.
Originally Posted by shandy294
I guess the d-shaft is more of an issue on ECs and CC. My intermediate bearing doesn't look too stout and not lubeable. I
How much did the 3 inch steel one run you?
I wouldnt really worry about it unless you have over 300whp, or plan on taking your truck upwards of 120 or so. And believe me, that feels REAL sketchy in a 4x4
I don't plan on exceeding 100 mph but you never know when you might have to. That's why I plan on eliminating the speed limiter when I buy a retuned PCM. As far as I know, reprogramming is the only way to do it. The issues about tire and driveshaft performance are important considerations too.
GM has been doing some strange things with driveshafts though and I wish I knew why. They went from two-piece units to one-piece alloy units to who knows what else.
My '02 K2500HD ECSB came from the factory with a huge one-piece alloy driveshaft. It looked like it was 5" - 6" in diameter. Due to some tranny shift problems, the dealership, in their infinite wisdom, decided that I needed a new nickle-plated yoke. The only way to get it fast was to order a whole new driveshaft. Guess what I got as a replacement; A 3" dia. STEEL shaft. Why? Where the alloy ones breaking?
If anyone has any inside info, I'd sure love to hear it.
Tin Foil Hat Wearin' Fool
I have already takin my truck a little over 120 and yes it is scary in a 4wd. You start floating all over the place so I dont really see myself going any faster bu would like to have the piece of mind that Im not going to chunk a driveshaft haulin *** down the freeway. And if all goes well when i come back from alabama this summer my truck will be putting out over 400hp to the rear wheels plus a 100 or so shot of nitrous so yeah Im probably going to need one.
I would feel MUCH safer with a 3" steel driveshaft, rather than the stock aluminum one. Ive had my driveshaft blow on the dyno, pieces went everywhere, even took out my tailshaft housing.
You know the work ive had done to my truck, i put down 344/322.
Vortec350ss
01-12-2016 10:36 PM
