muffler
muffler
im looking to get a borla xr1 muffler but was wondering if anyone new the difference in sound between the 12" and the 16" . will the smaller one always be louder?
im running pacesetters, ory, and a borla xr-1 with a 12 inch case. its pretty loud. mine dumped at axle and has quite a bit of resonance. id go bigger if i could do it over. or just go all the way out the back
also "gtols1truck" has the same setup buts his is all the way back. seems like his is a whole lot quieter by doing that..
i got the same set up.depending on how you run the tail pipe you see the difference in sound level.right now i have it dumped and i kinda like it but goin to change it all the way to the back in a couple of days.
i think ill probably go ahead and get it and run the pipe all the way back and if still too much drone in the cab i could always add a bullet to quiet it down some.
Ive heard gtols1truck's (sammy) but only at idle i havent been in his truck when driving on the freeway. i know it sounds pretty loud at WOT, but not sure about the drone at highways speed. i guess i could always call him to ask huh.
FlowmasterMufflers
09-18-2015 02:31 PM
