Muffler? Magnaflow,Flowmaster....
I am in the middle of the 4.8 buildup and I need some help chooseing a muffler. I already have a 3" QTP cutout to go on and now all i need is a muffler. But I cant have anything to load bc there is a noise ordinance that I have to pass when I go to get a inspection sticker. I am looking at a Magnaflow 3"in/3"out single pipe. I like it because it is stainless. But how load do you think it will be????? I also still have the stock muffler but I would rather have something that will sound good. Any suggestions????
Hookeer's seem to be known for thier flow. They are quiet at idle, but have a nice rumble at low throttle, and scream when you open it up.
They will hide a lope, unless you listen for it closely.
Here's some clips:
Through the muffs dumped in front of the axle. Mic is right next to rear wheel on the exhaust side.
http://www.woracing.com/truck/Sound%...%20no%20ac.wav
This is through the cut outs, same setup, but cut outs open. It will show you a good comparison for how much they quiet it down. Mic is in the same spot.
