Muffs
Old 03-19-2006 | 12:35 PM
ThunderZ28's Avatar
12 Second Club
Default Muffs
I am getting the Exhaust redone on the truck..
looks like I am going with the hooker mufflers..
but I see there are 2 diffrent setup...
they have an aerochamber, and
maximum flow muffler..
whats the diifrence between the 2?
gonna go with 3" all the way back.. and then dumped
whats your thoughts on these 2?
Old 03-19-2006 | 01:20 PM
Zick's Avatar
Old 03-19-2006 | 01:24 PM
ThunderZ28's Avatar
12 Second Club
I seen where the maxiflow flows up to 500+cfm
what does the aerochamber flow?
Old 03-19-2006 | 01:27 PM
Zick's Avatar
I've read about 400+cfm
Old 03-19-2006 | 01:32 PM
Zick's Avatar
Well, maybe not as much as I thought. Lots of google threads show around low 300+ cfm.
https://ls1tech.com/forums/showthread.php?t=113572
I suppose depending on pipe diameter, these results might change?
Old 03-19-2006 | 01:52 PM
bluecajun5.3's Avatar
11 Second Truck Club
i think the aerochambers will be sufficent enough for what your running. just make sure to get the center in/out, you can see right through it. i don't know too much about dumping it though, it'll probably put out alot of drone. i posted mine up on here yesterday, it sounds good just has the rasp like the transams and camaro's...
Old 03-19-2006 | 03:58 PM
ThunderZ28's Avatar
12 Second Club
I'm not worried about the drone...
you should have heard it before I started tearing it apart..
V8 can tell you...
cut outs directly under the passenger seat., and i usually had them open all the time.
there was no hiding from the noise of my truck...
Old 03-19-2006 | 04:20 PM
Midnight's Avatar
I like bluecajun's set up and I plan on running an aerochamber after the LT and ORY install. Souns great and I like that raspy sound like the F-bodies too.
Old 03-19-2006 | 04:24 PM
Scott Mills's Avatar
FlowChart Here is a flow chart by Spintech. Take it for what its worth.
Old 03-19-2006 | 04:31 PM
Zick's Avatar
Those seem extremely low compared to all the other flow charts out there.
Quick Reply: Muffs
