My 6.0 4L80E Build, So far...
#44
The Block, Pistons, Rods, Bearings, Cranks, Main Caps are all the engine shop. However I am still searching for a overdriven crank pulley (Harmonic Damper). Anyone know where I might be able to get one. I've done a little searching online with no results. What material should be used to pin the pulley to the crank shaft? I have an array of material in my shop from Stainless to Hastalloy X. I might be able to get a hold of a long inconnel aircraft rivit....could work nicely!
Also thinking about selling off the cam I bought and going with the GT2-3, but the max lift on the springs in the heads now is .570, you guys think it's worth the effort for the added performance? (remember it's not a track truck)
I decided I won't be using the truck for towing anything heavy. I have a shop truck, 09 F350 I can use if I need to tow anything big.
#45
Custm2500's Rude Friend
I was wondering what you were up to... I just got my second block back from the machine shop. My first block had 1 cylinder that had minor pitting. I think it will need to go .030 over. New one will go .010 with no problems...
#46
I think you should just stick with the first cam you already got. Aren't you using a Radix or something with this new engine??? I forgot what the final descions were... LOL
#49
Sorry for the long delay....But we have bought a new building for the machine shop and we have been going crazy prepping to move.
Here is what has gone on so far...I got my block back from the machine shop. Decked, Machined to 4.010, Cam Bearings, Balanced Crank, Weight Matched pistons & rods, and file fitted rings.
I am prepping to begin assembly, just as soon as I pick up the Clevite main bearings tomorrow, and Hit the block with a little Gloss black engine enamel this weekend.
Contemplating hitting the blower with some gloss black as well, what do you guys think?....Plan on going with copper valve covers
