My '95 240sx 347ci V8 Project
#51
Im not gonna get time to get on the computer to get you a link today so this is where its at...
goto www.zilvia.net
click on fourms
click tec talk (its near the top)
then it should be a sticky called FAQ V8 240
hope that does something for ya cause its like 12 pages.
goto www.zilvia.net
click on fourms
#52
So I got my head under the hood today and I realized something...I need better tools!!
I broke two screw driver's and a 12mm socket. I also can't continue until I get a set of metric deep sockets.
Kinda frustrating and difficult working on a car without proper tools. So here's a few questions until I run to Sears and get me a better set of tools...
Can I pull the fuse box and trash it or do I need to keep it?
Is this the condensor for the A/C?? If so I think I can keep it but if it isn't, what is it and can I throw it out too?
Power steering pump, keep it or trash it?
A/C compressor...trash it?
Oh yeah...what is this? Looks like a condenser but not sure, throw it away?
AND...Found out what happened to the engine!! Looks like a rod is sticking out the oil pan...
YUP looks about right to me
Here's the underside, I'm gonna drop everthing from the struts on down, have it come down as one big piece.
No more gear shifting
#53
That Black Plastic Thing Is The Evap Canister For Emissions.
Most Of The Pumps Etc You Can Scrap... They Wont Bolt To A Ls Motor
The Fuse Box I Would Probably Hang Onto... We May Use That As Our Power Center, Or We Can Go To Painless, Or Someone Like That For A Fully Funtional Ls1 Fuse Block.... But Well Talk About That A Lil Later
#54
Things I can keep and re-use so far as I know are the A/C Lines, A/C Condenser, overflow reservoir, and the power steering lines can be modded up to work with the 5.3L.
#55
Ok, sounds good. I'll scrap everything including the evap canister. What about that white canister, scrap that too?
#59
are you talking about the reservoir on the power steering?? or the canister with the black bracket going around it... the one with the bracket is the accumulator
#60
Ohhhhh gotcha gotcha gotcha. Got mixed up with what you were saying. Ok so keep the white plastic reservoir that's attached to the PS pump and then the white canister that's in the bucket with the black bracket is the accumulator.
So I'll throw everything out except for the PS reservoir and the condenser which is the radiator looking thing.
