My dashboard looks like a Christmas tree.....
Originally Posted by 1BADHD
That means its trying to engage!! Lucky it cant. That would be a ride would it? Cruising 60 or so and it goes into 4 lo!! After the smoke clears, tires stop squeeling and you get it stopped. I am sure you would have to clean the **** outta your pants!
KeukaZ71......GM says the ONLY reason that the "Service 4WD" light will light up on the '99's is a faulty switch (apparantly on later models it will light up for other reasons).....it does sometimes switch between 2HI and Auto4x4 by itself sometimes too
Nick99Chevy....BOTH lights are on because I pulled the 60amp fuse out of the electrical center to shut the pump off (it was running constantly and I don't want to have to buy BOTH a new EBCM AND a new ABS pump), witht he fuse only the ABS light is on but the pump won't shut off
SmokinRice...it's all yours when I repalce the sucker (you need a stealthy nitrious switch huh )
Ram4Pick
12-27-2004 08:53 PM
chris99gmc
12-26-2004 01:36 PM
renegade4e
12-16-2003 11:48 PM
