My DOD AFM Elimination Project
One other thing I did was install a IAT Sensor in the intake manifold. If you look at the picture with the mini K&N it is right above it. I plan to run methanol injection and want to see the actual IAT.
Got the motor running today. Next step is another tune from Justin at Blackbear Performance. The idle is NASTY!! I love it. Here are a few more pictures. I added 4 corner cylinder vapor porting. I ran dual lines to the radiator. Due to the extra tall valve covers I will need a longer plug wire. Just ordered some 10mm's off of ebay.
Cam Spec: 218 /226
595 598
113LSA +1 Advance
111 Intake Centerline
Comp/EPS Lobes
Cam Spec: 218 /226
595 598
113LSA +1 Advance
Comp/EPS Lobes
I know Mrgoodwrench3 already knows this but the LS7 cover he mentioned before is the valley cover. An LS7 front timing cover wouldn't fit without a matching crank and oil pump.
