My E85 Ethanol Gas Mileage :)
Again, this wasn't easy driving... it was kidnda goofin off in a way I just filled up and am going to drive this week without gaggin or bein hard on it. Just gonna cruise around and see how that works.
brick, im from off of grandparkway by cinco ranchish....
as far as the thread, i doubt youll se much power gain from E85 but who knows. theres a few krogers around houston that have it now.
Alot of Katy guys here. lol
I really like the E85. Its 105 octane so yes it will get less milage in our low compression motors, but if you ran a motor with 11:1 you would get as good as stock milage. The high compression takes agvantage of the higher octane where the lower compression cant effeciently use the higher octane. E85 is also a much cleaner burning fuel and has nearly no deposits like gasoline.
I took a trip over the weekend with the idea of runing E85 the whole way. The first tank got me 17.4mpg. After that tank I ended up putting 5 gallons of premium back in to get me to the next E85 station since the one I stopped at when I was real low had run out of E85. After that though I refueled with E85 and have been getting what I would guess to be around 16-17mpg still. There was alot of highway driving on the first tank, about 80%. Since then I've been running alot of everything kind of driving. After gas prices went up 30 cents in one day around here I plan to keep running it and tune for it.
Does anyone know what E85 goes for in thier area?
Originally Posted by Jeff12
can someone tell me if my truck is fuel flex and can run e85? its a 2003 avalanche 5.3L
I just looked and there's a bunch of stations here in town! There's on my way home from work too. $2.65/gal
So basically with 91 octane at $3.19/gal here at 17mpg I would break even if I get around 14mpg with E85.
Zippy, what did you do to tune it exactly? What's your target AFR while cruising and at WOT?
