Is my exhaust system too restrictive for my 6.0L? :TECH ONLY:
#76
Where did you get the settings? I just compared it to a '04 Silverado SS 6.0 file and they're all different, i'm not trying to knitpick just trying to help you figure out what might be causing problems in the tune.
#78
Do you have a degree wheel? If so, you can still degree the cam, would be easy to do w/ the intake swap going on. Just get a piston stop to find true tdc, set up the wheel and put a dial indicator on the pushrod (but don't let it fight the valve spring, or it will bleed down the lifter and give you a false reading).
I am new to efi, and have been racing carb cars for years, so I don't know the relation of kpa to vaccuum, but one thing that I used to do was watch a vaccuum gaugge at wot, if the vaccuum is more than 1.25 inches, then there is a pretty significant restriction in the intake tract. I have also ran 1.625/2.5 headers clear into the 10's and pushing 500 rwhp w/ 2.5" x-pipe exhaust, after switching to 1.75/3.5 w/3" x-pipe exhaust, we saw a gain of 22hp, but the major gains were over 7k rpm. I think your exhaust is fine.
