My headers are in contact with the chassis!
Old 04-15-2010, 06:45 PM
Hunt&Fisherator
silver-mod-o's Avatar
Less posting... More beating on **** with a hammer
Did an exhaust shop weld that up? If so I'd be back there getting it moved.. If its bolt together stuff from ARH, I'd make sure all the connections are right and can't be adjusted away from the point of contact. Beyond that, I'd be on the phone with ARH for sure...
Old 04-15-2010, 08:39 PM
PT's Slowest Truck
budhayes3's Avatar
Were the headers on there before you swapped the heads, or did you do them at the same time? If you were previously running the headers without problems and this occurred after the head swap, you should be able to adjust it back the way it was
Old 04-16-2010, 03:28 AM
GFYS and STFU
Spoolin's Avatar
So who did the install?
Old 04-16-2010, 04:51 AM
supercharged680's Avatar
not me lol.. i took it to a garage that builds engines and race cars.
Old 04-16-2010, 04:52 AM
yeah the headers where there.. and where fine.. i had a good amount of clearance.. the problem occurred after the head swap.. im waiting for the garage to reopen after the weekend to check it out.. its really annoying to drive !
Old 04-16-2010, 08:27 AM
I have a gauge for that
Atomic's Avatar
wedge a piece of plywood between the headers and frame. it will stop it for a while.
Old 04-16-2010, 05:46 PM
Foxxer's Avatar
Plywood? with this weather and heat It might catch fire lololol... J/K...
Superman09
09-25-2015 05:55 AM
Pontiac Derek
09-19-2015 01:49 PM
Pontiac Derek
09-18-2015 09:02 AM
Quick Reply: My headers are in contact with the chassis!
