my Hot Air Intake
Old 09-30-2008 | 01:09 PM
AdioSS's Avatar
12 Second Club
Default my Hot Air Intake
As you can see, I took off the plastic thing that goes above the radiator, so I'm betting that some cold air makes it over the radiator and core support to reach the filters. The filters and pipe are kinda small, but I got it off ebay for cheap. If/when I start making some power, I'll upgrade to 4" pipe. At this point I'm sure it isn't a restriction, and I was able to make the factory filter gauge thing work with it.
I intend on making a box to separate the filters from the rest of the engine bay and scoops that direct air from the grille area someday.
Any comments?
Old 09-30-2008 | 02:09 PM
outlawz2004's Avatar
I like it, can you send me the ebay store or a link.How much did it run you, and does it have any idle problems or anything. I have the K&N FIPK now, but I like the way that looks.
Old 09-30-2008 | 02:38 PM
AdioSS's Avatar
12 Second Club
It's a "BOMZ" intake for a C5 Corvette. I got it from this guy: http://myworld.ebay.com/eautotuning
I just noticed that he never left me feedback though
Old 09-30-2008 | 02:41 PM
AdioSS's Avatar
12 Second Club
Oh yeah, you will need some kind of boot to go between the MAF and the TB. I had the perfect size one laying around that was left over from my Impala SS. And I found a grommet at an auto parts store that worked perfectly to seal the restriction gauge into the hole that the Corvettes use for an O2 sensor of some kind.
For a higher power application, I would use something like this that a decent muffler shop should be able to make.
You would probably need to cut down the Height a few inches and maybe the width also.
Old 09-30-2008 | 06:19 PM
blueflamed03's Avatar
looks cool...like it
Old 09-30-2008 | 06:29 PM
buzzkillwill's Avatar
yeah, just noticed the location of the MAF. How is that working- Doesn't the MAF sensor think it's further away from the TB?
And is that a stock TB?
Old 09-30-2008 | 06:39 PM
AdioSS's Avatar
12 Second Club
no problems whatsoever. I had it with just a filter on the MAF for a while.
The MAF and TB are both stock.
Old 09-30-2008 | 06:55 PM
Oh, okay. I like the set-up. Have you thought about extending the tubes out, towards the fender wells.
I think trying to get cool air through the radiator may be tough....
Old 09-30-2008 | 06:57 PM
silver-mod-o's Avatar
Hunt&Fisherator
I believe that hole is where the 'vettes IAT sensor would go. Yours is built in the MAF
Old 09-30-2008 | 08:31 PM
Hawk179's Avatar
Bad idea. Taking that top shroud off for the radiator is a no-no. Thats the only thing that keeps air flowing to the radiator. Plus, you are now taking direct hot air from the back of the radiator. Remember, hot air rises faster than cold air.
R
