My LQ9 6.0l Build and Swap Thread
Old 07-02-2011, 06:00 PM
  #101
TOTM: June 2007
bgray's Avatar
As promised!
Had a great Day, Started at 8am, Had the Whole thing torn out by 12. Everything is stripped down bare, rad supports, headlight buckets etc I pulled it all apart for refinishing.
Got the Front of the Frame Cleaned up, Used some purple stuff, scrapper, and a BA Gas Pressure washer. Everything went according to plan. Tomorrow Im gonna paint the Frame, and see what I need for Loom to reloom the Harness. Alot of the harness is mint, but some isnt so Im gonna redo the whole deal.
Ordered a new Starter, Alternator, Rad, 02 sensors, Tranny lines, AC Reciever Dryer, and a host of other stock repalcements which will be painted.
Old 07-02-2011, 06:01 PM
  #102
TOTM: June 2007
bgray's Avatar
On a side note, Does ARP make Nice Flywheel Bolts or even new Transmission bellhousing to engine bolts?
Old 07-03-2011, 02:24 PM
  #103
jhe2003's Avatar
oh wow its coming out nice!!
arp does make flywheel bolts I believe.
Old 07-03-2011, 05:28 PM
  #104
TOTM: June 2007
bgray's Avatar
todays progress. left the good camera at home, so just took a few blackberry ones.
Got alot painted!
Old 07-03-2011, 05:30 PM
  #105
TOTM: June 2007
bgray's Avatar
by chance know the arp part number??
Old 07-05-2011, 09:52 PM
  #106
Fastest D1 Procharged Truck
02_Orange_D1SC's Avatar
looking good i just started pulling my motor in my truck also. what did you use to paint the frame.
Old 07-07-2011, 02:19 PM
  #107
TOTM: June 2007
bgray's Avatar
I used a Rock Hard textured Rocker Gaurd, I use it alot, my frame on my 2500 is done it in. Much tougher then some spray bomb.
So..I should be able to use my 6.0L flywheel correct?
Old 07-12-2011, 11:04 PM
  #108
TOTM: June 2007
bgray's Avatar
Took me forever to find this dam camera, found it AFTER i was done tonight. Pic tomorrow of fast loaded with sensors and all
Whole bunch of ****
New alt and starter
Flexalite Trans Cooler 10x21x1.5"
Flexalites cleaned and brackets repainted
Repainted to match other satin stuff
Fully reloomed,taped, and heat taped harness in a bag so she dont get to dirty
Painted hinges while i was there
AC and PS Lines, Gotta see how they will stand up to the paint hmmm
Rad support piece(Support painted in other room) New Rad and Condsensor painted
All the nuts and bolts
Old 07-13-2011, 06:36 PM
  #109
Laid Back
Beatdown Z's Avatar
Looking GREAT! You have a lot of patience for all that. Not sure if I could handle going that far to make my truck look good. Props.
Old 07-14-2011, 08:07 AM
  #110
TOTM: June 2007
bgray's Avatar
Its all in the details.
Here are some pics of the engine mocked up
here is a picture of the fast intake and stock fuel rail setup, fw guys were pming me
new engine mounts
Quick Reply: My LQ9 6.0l Build and Swap Thread
