My LQ9 6.0l Build and Swap Thread
Old 01-12-2011, 06:35 AM
  #71
Coban's Avatar
Originally Posted by twolow02fransen
damn a torquer v3 cam is a big cam for a heavy *** truck. what you plan on running for a stall and rear gears.
Originally Posted by bgray
1999 GMC Sierra with stock LQ9 6.0L short block, 65cc PRC stage 2.5 LS6 heads, .054” gasket, stock truck intake, 78mm TB, A4 with 3600 stall, 4.10 gear, 1 ¾” long tube headers with dual cats, 6500 rpm shift points, 6800 rev limiter.
Done and Done.
Old 01-12-2011, 08:10 AM
  #72
JFOLM's Avatar
There's something about seeing those nice shiny new parts.
Old 01-12-2011, 08:42 AM
  #73
Tin Foil Hat Wearin' Fool
1slow01Z71's Avatar
With the added compression that cam and converter ought to run pretty good in an rcsb. The only things I would change would be go with some of TSPs 1 7/8 headers, ditch the cats, and go with a .04 headgasket for better quench. That would net mid to low 11s CR wise(off the top of my head) which would make for a nice street truck. Maybe later get the converter restalled to closer to 4000. Just look at skeets truck and copy it if you want a badass 6.0 powered truck
Old 01-12-2011, 08:50 AM
  #74
sleeperlqx's Avatar
well said. I would love that setup, but my weight KILLS me. I have a Tahoe, just dont know if 217/224 would be too small for my Yank 3200 stall converter with Truck intake... But Yea, I would like to run like Skeets truck.
Old 01-12-2011, 08:51 AM
  #75
Senior Member
Country Boy's Avatar
Dang.. didnt see on the other forum that you had the LSXRT.. Thats some hotness.
Old 01-12-2011, 07:15 PM
  #76
TOTM: June 2007
bgray's Avatar
I guess ill update the top post, my headers are 1 7/8 with no cats and getting a 4000k triple disc stall. I guess we will see how it works, i didnt want to run the same setup everyone else does witt a tr 224 pr 228. I think its all going to work very well together and performance well
Old 01-12-2011, 07:16 PM
  #77
TOTM: June 2007
bgray's Avatar
The lsxrt is sick in person....massive
Old 01-17-2011, 11:46 PM
  #78
Sinistersilverado's Avatar
So whats the weight difference from a single cab to my extended cab? would this cam be too big for me to run on my truck? was thinking this or a little smaller with a 3600 triple disk convertor. Also have 4.10's in the rear.
Old 01-18-2011, 01:02 AM
  #79
BadAssChevy327's Avatar
subing for sick build
Old 01-18-2011, 02:15 AM
  #80
PT's Slowest Truck
budhayes3's Avatar
That's a nice pile of parts for sure, your truck's going to be a monster when it's done!
Quick Reply: My LQ9 6.0l Build and Swap Thread
