My Secret Plan Exposed!!!
Old 08-15-2004, 03:41 PM
Black Blown 02's Avatar
Originally Posted by greentahoe
What he is trying to get at is that it may or may not make that much boost, but with the high IAT's you wont get much of a rwhp increase. Hot air is worthless and that blower isnt very efficient meaning quite a bit more hot air than a more efficient blower and ALOT more hot air than an intercooled setup.
YEP.
14 Second Truck Club
What about using the methanol injection kit that STS sells?
greentahoe's Avatar
BTW, why are you planning on buying expensive heads?? Ive always heard that heads do very little on FI setups. A pair of 6.0 heads will drop compression, but why do that to run only 6-7#??
I'd scrap the heads and use the money from the Magnacharger and heads to get a Turbo . Now that seems to be where the money is!!
Old 08-15-2004, 03:46 PM
Also remember that with a supercharger, it takes HP to drive, and when you run really low boost, you barely make up for that.
Old 08-15-2004, 03:49 PM
What about using the meth injection kit?
Crap, now I'm stuck in the middle again! Supercharger or built LS1?
Old 08-15-2004, 03:52 PM
Sport Side's Avatar
im glad you checked with some of these guys before you went and started
Old 08-15-2004, 03:59 PM
greentahoe's Avatar
Well if I had it to do over I would have built a forged 6.0 and run nitrous then eventually a Turbo.
A 5.7 with a nice cam, bigger converter, and a little gas or a turbo is the ultimate setup IMO.
Meth will cool things, BUT you still would have spent a decent amount on an old out of date blower that WONT have the ability to give you what you will ultimately want... MORE POWER.
BTW if you are planning on lower boost, you dont need all that ARP hardware either.
What do you have now as far as parts for the new buildup??
Old 08-15-2004, 04:03 PM
I think you should do yourself a favor and put that m90 on ebay. That way you won't look at that as an option. The power you're looking for, needs a bigger blower.
Old 08-15-2004, 04:25 PM
Thanks for the info guys. I guess I'll stick with my LS1 build-up
Wolftrk99
12-03-2015 08:12 PM
nabozny21
10-17-2015 07:47 PM
JordanH
10-03-2015 03:59 PM
blackedoutchevy22
10-01-2015 08:07 PM
Quick Reply: My Secret Plan Exposed!!!
