My turn, Camshaft suggestion
adriver (02-22-2023)
Custm2500's Rude Friend
That sounds like right about what every recommendation I found was. I was hoping having a manual would give me more options. Specifically to raise the powerband up from 1K to 3K+. Thinking I could get a slightly smaller band. but that would do a little more. (just not even sure if that's how it would work).
I drive it pretty aggressive, If I'm doing 70 in 5th, half the time I shift it to 4th and go, and half I'll drop it to 3rd at 5K rpms, and floor it for 800 more, for no other reason, then I like to try to have control over where I am in relation to traffic. I rarely drive in slow traffic. It's pretty much only when I get stuck in it because I'm just out and about, (maybe once a week or every other week). Even the slow areas around the neighborhood are decent hills, and I have to keep it revved higher in 2nd and 3rd. It just seems like when I need power, it's a lot more of upper RPMs, going up through the end of third. The only time I'm below 3Krpm is when I'm from a stop. If I have less than half a tank, I can't get on it anyways or I'll spin in first.
When you raise the Powerband like that It will effect your cruising and take off. You will hate driving it around... It won't be efficent until you get up into the powerband of the cam. If you listen to Richard Holdener in all the testing and comparison, He explains this. Its hard to show on a dyno but he has some were they pull it down to like 2k or 2500 to compare and you can see the loss on the low end to the point where it starts to get into it power band of the cam.
Not that I condone such behavior....
I've been back here for about 5 years, and every inspection I've gone to they have a pit and go underneath. I know long tubes are also louder, which I didn't want. This exhaust should be good for a 6.0L too. I think longtubes sound obnoxious, and this sounds great. I'll see if I can make a video and try to post it.
