Need a 200+amp alternator!
Old 04-21-2004 | 06:37 PM
F8L Z71's Avatar
Default Need a 200+amp alternator!
My buddy has a fairly large stereo system with a huge current draw and I need to source a 200+amp alternator that puts out good voltage at idle and low rpms.
Which ones are you guys using?
This is going on a 99' Suburban with a small case alternator.
I found one that is 200amp but is a large case. I am assuming that the companies you guys use have a custom bracket to adapt to the larger case?
Any help would be great
Old 04-21-2004 | 06:47 PM
Yelo's Avatar
Powermaster makes a 200amp small-case direct-fit alternator for our trucks
if you need more than 200 amps consider a couple of gel-cells mounted under the bed and a few stiffening caps inline to the amps
Old 04-21-2004 | 08:07 PM
Caps are mearly a band-aid. They honestly will only help in short term use. I would sudgest working on dual batteries or running dual alternators. It's what I'm gonna do.
Old 04-21-2004 | 08:47 PM
This is the place I went with. alternators It fit in the stock location. I had it on my last truck for about 2 weeks. Will let go for a good price. I even have the pigtail for it. 200-amp. PM me if you're interested.
Old 04-22-2004 | 07:09 AM
mudz5.3's Avatar
MrAltenator.com I think. Do a search for 200 Amp Alternator in the Perf section. There's a bunch of links in there.
BenKey, pm sent.
Old 04-22-2004 | 09:06 AM
1BADHD's Avatar
I got mine from AlterStart. Its a stock case with the 200 amp internals. It does require a adapter to the stock harness. But they provide it.
Old 04-22-2004 | 09:21 AM
tbyrne's Avatar
I'll probably be going with one of those for my Suburban. I need the upgrade for all of the HIDs and electronics that are running in there.
2002 8.1 Silverado HD - Full Throttle lift, 37" tires, Comp Cam, TOG headers, Volant induction plus more!
2002 8.1 Suburban -Intercooled Whipple supercharger, 22" wheels/tires + more - 407hp/558 ft-lb torque at the rear wheels - 13.93 @ 95.79 MPH
Old 04-22-2004 | 11:50 AM
benpimpin1's Avatar
www.h-o-alternators.com They are a a great company , check out there page lots of useful info. for calculating power draw and how big of alt you actually need. I wouldn't get a cheap brand alt from wherever, the cheap alts dont put out the rated output at low rpms and the 200 amps rating is when they are cold, you may get 120-130 amps at idle when the alt is hot. If you dont find anything at ho that you like do a search for dominick iraggi, he should have what you need, but go to ho first.
Old 04-22-2004 | 02:13 PM
01Blackerado's Avatar
Before you go expensive moding with that Alti. try an optima battery yellow top D34/78 i believe it is!
Old 04-23-2004 | 08:51 AM
retsell's Avatar
the only companies that IMO make decent alternators is Wrangler and Ohio Generator. They are expensive generally about 5-700 bucks, but they have great output. I've used them in several applications and always have good results. The ratings may seem low, buy its because they dont bullshit, especially Wrangler.
I run a car audio shop in Norman, OK. So if anyone needs some stuff give me a shout. (405) 579-1204 Advantage Audio
