need advice with maf!!
1 Post
i relocated my maf sensor to directly in front of the throttle body and now i am having problems with my truck running rich and throwing p0172 p0175 which is rich on bank 1 and 2 .Then p1133 which is insufficient switching on o2 sensor i am going to relocate a new iat sensor to where my maf sensor used to be but will the maf off of a 2000 4.3 truck work they have the same numbers and look the same.thanks
1 Post
well it works good with my nitrous set up but the difference between the fbody and ours is they have a seperate iat sensor upstream and thats the only thing i can think has changed.
someone from here told me that if you dont have a straight path to the maf, like on fbodys, that the maf will not work properly because the bend in the intake right before the maf causes too much turbulence or a problem with the air flow and the maf reads wrong. just what i heard
Bryan
Bryan
