need build advice 5.3 lm7
i have lm7 99 model in Silverado regular cab, i want to upgrade it for FI and want it to be capable of handle anything I through at it. I have multilabel questions for my build, FYI it will be DD and offroad. and the budget at max 14k.
1- should I upgrade my internals to forged or gen IV will be good.
2- what turbo setup is best for me. ( I would prefer almost instance boost)
(the camshaft I need it to be smooth as stock I think ls2 or ls3 camshaft is what I need)
hp goal 400-500rwhp
best fuel I can get is 91.
if you suggest something please write your reasons to pick whatever you picked
thanks,
hp goal 400-500rwhp
thanks,
Gen IV is fine for those goals.
You can get an aftermarket cam that will be smooth and provide better gains.
68Formula (03-27-2024)
Call around and ask
Anything with -20* or less overlap @ 0.050" lift should be capable of being tuned to idle like stock with the idle airflow and timing tables properly adjusted by a competent tuner. You could probably get away with a little bit more if you're willing to bump the idle rpm up along with the other adjustments. Summit 8727R1 200/205 113+ 4 .550/.550 or CamMotion 5.3L Stage 2 206/210 115+5 high lift .553/.553 fit the bill (both are available thru SummitRacing). Either would be better than the LS2 camshaft.
Summitracing (04-04-2024)
