Need cam help
Old 08-08-2005, 07:26 PM
Dark Halo's Avatar
Default Need cam help
I have a 230/236 .591/601 @110 comp cam. I am trying to figure out if I can run this cam on a LQ9 6.0 with flat top pistons? I will be using unmilled cnc'd bigger valved 6.0 317 heads. Is anyone using a cam like this with a flat top piston without valve reliefs? Any help would be great
Old 08-09-2005, 07:09 AM
Dark Halo's Avatar
anybody have anything on this?
Old 08-10-2005, 09:57 PM
Dark Halo's Avatar
cam guys I need your help. My new 6.0 I got is a LQ9 and I already have the cam
Old 08-10-2005, 10:04 PM
I'm not sure, but I think that would be alright for your piston to valve clearance. Just don't quote me on that.
Old 08-10-2005, 10:14 PM
Dark Halo's Avatar
the piston to valve clearance is the main concern I know I seen the flyer is runing a very large cam on a 5.3 but I do not know if he has flat tops, or if he has valve relifs cut in them
Old 08-10-2005, 10:15 PM
white1's Avatar
Damn thats going to be close.
Old 08-10-2005, 10:34 PM
This might help you a little. Got it from a stores website.
Item:
Camshaft: 237/242, .603"/.609", 113 LSA - Clears Stock Pistons with Stock Cylinder Heads!
Description:
This camshaft has shown up to 65 rear-wheel horsepower improvements with stock cylinder heads in place! It is the most aggressive camshaft we offer for a stock-cid application that will clear factory pistons with stock cylinder heads
Old 08-11-2005, 08:02 PM
Dark Halo's Avatar
Item:
Description:
do you know if the lsa will affect pistion to valve clearance in any way?
2500ZL1
01-25-2016 06:30 AM
lawhitediamante
08-12-2015 12:14 PM
steves86ta
07-28-2015 10:21 AM
WICK3DxGATA
07-21-2015 06:59 PM
projectnightcrawler
07-19-2015 11:30 PM
Quick Reply: Need cam help
