Need engine swap help 04 5.3 to 07 5.3
Old 10-08-2009, 11:57 AM
matchstick's Avatar
Default Need engine swap help 04 5.3 to 07 5.3
Can you guys tell me the difference in the 2 engines and what I'll have to do to make the 07 work in my older model truck?
Old 10-08-2009, 01:06 PM
terravast4's Avatar
Why are you swapping the 07? Why not an older 6.0 ?
Old 10-08-2009, 01:50 PM
PT's Slowest Truck
budhayes3's Avatar
If you're going from the old to new style (would that be GENIII to GENIV?), I *think* you'll need:
Lingenfelter Inverter box (for 58 to 24 tooth reluctor wheel on the crank shaft)
Lengthen harness to cam sensor, assuming that you're using the timing cover and cam sensor from the new motor
Lengthen harness to knock sensors, as they're now on the side of the block instead of in the valley
And I'm not sure what else....
If it's an 07 classic, it's a direct swap
Old 10-08-2009, 02:27 PM
matchstick's Avatar
Because it was a cheap replacement.
Bumpers
08-04-2024 09:44 PM
GrooveCityZ71
08-31-2015 12:05 PM
Choda
07-21-2015 03:47 PM
06 4.8
07-15-2015 07:17 PM
Mark_k
07-09-2015 12:37 AM
Quick Reply: Need engine swap help 04 5.3 to 07 5.3
