need headers install guide
#21
Sometimes lifting the motor helps. It comes down to what you have available at your disposal.
#24
100% Redneck
On the GMT-800 2wd trucks I install from the bottom although the pass side can install from the top. I remove both heat shields for extra clearance and they do not get reinstalled. I pull the bolt out of the steering shaft to aid in bolt/gasket install. It's a good time to install spark plugs while the shaft is out of the way. With Speed Engineering headers the drivers heat shield has to be removed for the o2 sensors clearance. That o2 is super tight to the floor pan without the heat shield installed. You could trim out the shield for o2 clearance if you are **** about keeping the heat shield.
Get the ICT Billet header bolts as they are zinc plated and will not corrode inside the head. Always use new GM exhaust manifold gaskets or the equivalent MAHLE MS16124 gaskets to save some money. Don't use the cheap bi-metal gaskets that come with the headers.
tjmath (11-14-2020)
zblee
63
06-10-2023 01:25 PM
zblee
08-03-2015 03:45 AM
