Need Help/Advice on installing injectors
I just recently purchased a set of 8.1 liter injectors from one of our board members.Should have them by end of the week.What will I need in order to do the install? And What all is involved in doing it? I have the whipple charger,Will it have to be removed to gain access?
Thanks for any input,
Randy
Randy
Re: Need Help/Advice on installing injectors
Dosnt pertain to the physical install, but have you alread spoken with Diablo about changing your tune? Are you axeing the supplimental Whipple injectors and computer?
8 psi? Go ahead and go 9-10psi. I ran at least 8 psi ever day when I had my Whipple, just make sure the crank pulley is not coming off.
I might go 9-10, but I allready have the 8 pound pulley,so I'm going to try that first.If I have good luck/results with it, then I might up the boost some more
lxcoupe
07-21-2015 02:12 AM
