Need help ASAP
12 Second Club
Need help ASAP
driving around today, my truck died on me.
I pulled over to the side of the road into a parking lot, and after about 5 min of playing with it, it finally started.
got home, started cleaning the engine bay, stated the truck up to warm up the motor, and while it was idling it died again, now It wont turn over. it will crank but want start,
anyhelp here?
need to get it going ASAP, before the wife gets home and things I was installing something else on it and broke it.
anyhelp here?
Try checking the battery connections, grounds mostly cause problems like you state. friend of mine had a broken ground cable and truck would run for a while and kill, then start right back up and run bad.. Grounds cause lots of problems.
12 Second Club
well I disconnected the battery and then reconnected it, and it started right up, but now I have a code thrown and it seems to miss every once and awhile when you get on it.
I am willing to bet I either got some bad gas or the fuel pump is going out.
Truck addict
i was gonna say put gas in it! as a joke. but it does sound like a fuel pump. does it make the primeing noise when you turn the key to on but not start it? if it isn't then that would be a clear sign thats the culprit.
Cuz I AM a BADMOFO
Ususally when a fuel pump goes...it goes totally. It may be a fuel pump, but usually they won't surge like that. I'm betting its ignition related.
