NEED HELP ASAP with radiator
There is a black plastic prtector on them, then there is a metal clip on there. Once the metal clip is removed, the lines should pull right off. It may take a little wiggling to get them removed.
Adkoonerstrator
There is a little clip tool you need to get those out. It's almost like the fuel line removal tool. You should be able to get one at any auto parts store.
You can also just take the fittings loose outta the radiator like Die4Bowties mentioned.
Tigger Welder
10-01-2015 08:41 AM
