need help flexalite efans
Old 03-04-2007, 12:35 PM
9 Second Club
1fast1slow's Avatar
Default need help flexalite efans
i have the flexalite efans with the vsc module and i hooked all the wire up where they should go to the best of my ability using instructions printed off of the flexalite website. what happens is when i hook up the primary power cable the fans come on. No indicator lights come on while the fans are running though... did i do something wrong or does anyone have any suggestions?
thanks
roger
Old 03-04-2007, 03:05 PM
YenkoST's Avatar
Sounds like you might have the ground and negative reversed or you have the remote switch on(if you have one) or A/C on with the ignition on but don't know why you would be putting the power wires on with the ign. on so I doubt that's the case. On those fans, make sure you are looking at it from the right angle. On mine, my VSC was mounted upside down and I had to flip it around to make sure it was right. LMK if its still doing it after you check it out.
Old 03-04-2007, 06:11 PM
9 Second Club
1fast1slow's Avatar
thanks for the help... i have the fans off the truck right now, but i checked and i believe everything is hooked up correctly. I unhooked the ac compressor wire and also the ignition positive signal wire, then put the battery positive wire together and the fans come on but no lights on the box come on. Am i correct to assume that the positive to the battery should not be connected on the inside of the vsc until the box is turned on with the ignition? I hope this information helps. I seem to have bad luck with modding!!!! This is the 3rd problem ive had!!! (1 broken lv5 flt, 2 dynatech lt high flow cats hitting under the floor pan,)
THANKS FOR THE HELP!!!
Old 03-04-2007, 07:53 PM
YenkoST's Avatar
Well, you should have 1 light one(a light to says its on) but they shouldn't come on really but they will b/c the ignition doesn't feed them power but the battery does through a fuse.
SS94S10
01-03-2019 01:57 PM
Porscharu914
14
01-20-2016 10:45 AM
Velocity1
09-22-2015 01:32 PM
bluebommer07
09-20-2015 08:42 PM
94f150
09-13-2015 06:39 PM
Quick Reply: need help flexalite efans
