Need Help Getting the Stock Harmonic Balancer/Pulley off
Old 05-07-2009, 04:39 PM
  #31
dug
Banned
dug's Avatar
I cant find anyone locally for a threaded rod. Does heating up in the oven really work. ITs fuckn 105 degrees out here in phoenix. Im not turning the oven on for nothingl.
Old 05-07-2009, 05:03 PM
  #32
jakebdb56's Avatar
That spec of all-thread is kinda hard to come by in local stores. Zach had to order it from some place online. Baking the pulley works just make sure you get a good couple of threads into the crank snout before you start cranking on the bolt to push the pulley on.
Old 05-07-2009, 07:43 PM
  #33
Tootall's Avatar
yes it works . .
Old 05-07-2009, 09:09 PM
  #34
neilownz's Avatar
Can use a pot of boiling water maybe or the outdoor grill if you dont wanna fire up the oven.
Old 05-07-2009, 10:28 PM
  #35
jakebdb56's Avatar
lol what's wrong with using an oven? It doesn't take long at all.
Old 05-07-2009, 11:41 PM
  #36
GFYS and STFU
Spoolin's Avatar
on the oven comment!!
Old 05-08-2009, 12:16 AM
  #37
neilownz's Avatar
You should get one of those solar ovens.
Old 05-08-2009, 02:48 PM
  #38
dug
Banned
dug's Avatar
meh, I just got me a threaded rod. I should be back together in the next 5minutes.
Old 05-08-2009, 03:28 PM
  #39
hirdlej's Avatar
I've used a longer bolt on 6 installs now. Don't believe everything you read about crank threads getting stripped........
Old 05-08-2009, 06:18 PM
  #40
11 Second Truck Club
joeyc125's Avatar
I heated all of mine up, i've done 4 or 5 now and it works so slick you will kick yourself for screwing around with anything else. Just take a piece of a 2x4 and give it 2 good whacks and its all the way seated.
Quick Reply: Need Help Getting the Stock Harmonic Balancer/Pulley off
