Need help with hurst roll control
I got my hurst roll control in and Have no idea what to do. Has any of you installed one on your truck? Also What parts do I need for the install? I can't tell where I will need to run the lines at? Will I be runing the line to the ABS controler? Any help would be great thanks
roll control
Dang it's been so long since i did the one on my Z, um.... i know on my camaro you used the line that fed the front brakes, there is one line that goes into the block for fron, and one for rear, you disconnect the front in line, run that to the line lock, then out of the line lock into the front in on the block, that way it holds pressure to the front brakes when the solenoid is engaged.
yup
Yup, i climbed under my truck today, and the abs stuff is mounted to the frame under drivers seat. Easily accesible, PITA to work upside down on your back, but at least no need for a hoist.
2002_Z28_Six_Speed
10-04-2015 01:34 PM
