Need help identifying engine 07-09 Avalanche
So there is a wrecking yard near by and Ive been wanting to get a spare motor so I can have it sent to the machine shop and not have my truck down for a while..
This motor is real clean, sitting outside under a carport like structure and I do not know how to tell if this is a 5.3 or 6.0 or what options were even available for the avalanche..
It has the front accessory brackets installed.
im not sure if this helps but the throtle body mounting poriton of the manifold was pointing upwards a bit and was 4 bolt. dont know if thats how all of the newer manifolds are but thats the only other observation I made.
anyone with info, post up..
thanks,
clint
thanks,
clint
PT's Slowest Truck
That should tell you, or you can check the RPO codes in the glove box...I'm sure someone here has them and can post them up for you. Most of the Avy's are 5.3's I believe, unless it's a HD Avalanche. If I'm right about the HD thing, you should be able to tell by counting if it has 6 or 8 lug nuts...but I'm not 100% sure about that.
Get the casting number off the block is the only way to tell.
I believe you basically have four options:
L76 (6.0L, cast aluminum, AFM, VVT)
LMG (310hp 5.3L, cast iron, flex fuel, AFM)
LC9 (310hp 5.3L, cast aluminum, flex fuel, AFM)
LY5 (310hp 5.3L, cast iron, AFM)
04BlackGmc
07-16-2015 04:10 PM
