Need help removing fan from old water pump.
Old 07-16-2010, 09:09 PM
SUPERCHARGE's Avatar
Originally Posted by wentbig
Pipe wrench jaws almost closed where the belt would ride. Shock the wrench that is turning the nut with a dead blow hammer or a single jack 4# hammer.
This indeed did the trick. Didn't think a pipe wrench would have that much grip. Thanks for the tips peeps
Old 07-16-2010, 10:57 PM
2001CamaroGuy's Avatar
What I do is to take a C-clamp and clamp the belt together (across the tensioner) thereby making it as tight as possible (I keep tightening till the belts touch each other). That holds the water pump from spinning and allows me to use a pipe wrench on the nut. Hit the handle of the pipe wrench with a hammer and it will eventually shock loose.
Old 07-16-2010, 11:39 PM
11 Second Truck Club
fastrt's Avatar
good deal, glad you got it off
Old 07-17-2010, 04:07 AM
To be more precise I used a size 18 pipe wrench and locked it on the dead pump pulley's lip (which is completely destroyed now, so NOT a good idea to try this method if you're planning to keep the pump.) And then I used a Massive adjustable wrench on the bolt.
Big pipe wrench and massive adjustable wrench is a killer combo
SlvrSierra4.8
10-01-2015 09:39 PM
Tigger Welder
10-01-2015 08:41 AM
Shotguntommy
09-15-2015 05:24 AM
97gmc
22
09-08-2015 10:56 PM
Alvin@PCMofNC
09-03-2015 06:38 AM
Quick Reply: Need help removing fan from old water pump.
