Need help with some 3.905 mahle
Old 02-09-2012 | 09:24 PM
kevhill85's Avatar
Default Need help with some 3.905 mahle
Is this a set of 3.905 pistion or 3.910 pistions? I had a 5.3 block bored to a 3.905.. These pistion seem very tight in the bore.
Are these pistion for 3.910 bore..
Old 02-09-2012 | 09:36 PM
TXSZ66AVLANCHE's Avatar
You bored a iron block bigger than a LS1? Dayum
What you have here is a 3.905 with a .005 oversize, so.....3.910
Old 02-09-2012 | 09:56 PM
mitchellmade's Avatar
MASS seller approved
Pistons are 3.905,the rings are 5 thousands overthe piston size so you can file fit them , are you doing that part yourself? when you had it honed did the machine shop have a piston to base off of, i only ask because different manafactures have different tolerances wondering if they based the hone off of your word of 3.905 or measured the piston . depending if your spraying it or fi or na is how should figure out your ring gap guidelines should have came with the rings
Old 02-09-2012 | 10:00 PM
kevhill85's Avatar
Yes, I had a 5.3 block bored over
Old 02-09-2012 | 10:12 PM
kevhill85's Avatar
Well ... I order piston for a 3.905 bore. Can you bore a 5.3 block to a 3.910 bore safety???
The shop bored the 5.3 block with out the piston. I guess summitracing sent me the wrong pistons
Old 02-09-2012 | 10:18 PM
Why didnt you bore to the stock LS1 3.898 bore?
Old 02-09-2012 | 10:22 PM
kevhill85's Avatar
Haha, No other reason then I wanted a 3.905 bore
Summit show they are for 3.905 bore
Mahle LS1314905F04 - Mahle PowerPak Piston and Ring Kits - Overview - SummitRacing.com
Old 02-15-2012 | 10:59 PM
did you file fit your rings yet? what gaps did you go with?
Old 02-15-2012 | 11:30 PM
kevhill85's Avatar
Yes ,I filed the top rings .022 and sec .024
FlyingLow
11-24-2015 11:05 AM
ssnovaturbo
09-03-2015 12:56 AM
beastmode
12-26-2008 04:58 PM
Klive
03-05-2008 09:32 PM
Grey Silver
11-01-2006 12:44 AM
