Need help!! Too rich after head, cam , nnbs intake swap
Old 02-19-2013, 02:25 PM
MASS seller approved
Petey62782's Avatar
Thanx for the reply gamble . I'm going to recheck all the connections and I could be wrong but a vac leak I thought it would run lean not rich ??
Old 02-19-2013, 05:01 PM
Vortec350ss's Avatar
Are you sure that you went with the 44# marines. I think that manifold comes with 36# injectors if they were from a flex fuel 5.3.
Old 02-19-2013, 06:52 PM
Petey62782's Avatar
The manifold is a nnbs but its got a custom fuel rail crossover to maintain factory return style lines and I'm sure of the injectors part # 17113739. I also spoke to the tuner to make sure he has all the right info and he does he knows what parts I have including the injectors and they said it may take a couple of retune to get the injectors dialed in. Does that sou d right ?????
Old 02-20-2013, 09:01 AM
gagliano7's Avatar
If you had a vacuum leak the 02's will try adding more fuel to fix problem.
Old 02-20-2013, 10:35 AM
Petey62782's Avatar
Problem solved the tuner had alot on his plate right now and they forgot to scale the new injectors. . **** happens we're all human. But I give him credit for admitting mistake and doing the right thing!!! :-)
OHsixLS3
12-27-2016 09:30 AM
fat tony157
07-16-2015 12:35 PM
06 4.8
07-14-2015 08:09 AM
chevy1224
07-13-2015 07:50 AM
blackdc3
07-07-2015 07:52 PM
Quick Reply: Need help!! Too rich after head, cam , nnbs intake swap
