Need More power!!!!!
Old 10-05-2004 | 02:09 PM
onyx's Avatar
14 Second Truck Club
Originally Posted by Snafudilligad
If you stay drunk and in the passenger seat it is unbelievable how fast your truck will feel....with nothing else added to the mix but some liquor in your belly.
i will so vouch for that.
onyx's Avatar
or you could go the route of a tuune... that in turn will set you up for some future mods as well.
Old 10-05-2004 | 02:30 PM
snoman's Avatar
Originally Posted by Noyzee
Cheep as possable! this is a daily driver/work truck/plow truck/tow rig
it is a 03 2500 hd with 6.0 4:11 gears already.
the cheeper the beter cuz most of my money goes to my car
Do you have oversized rubber on this trucK?
Old 10-05-2004 | 02:36 PM
JERRY2500's Avatar
STS and Nelson tune, I have Proof it works. Check Sig
Old 10-05-2004 | 02:42 PM
Scream's Avatar
MOOBIES Moderator
An STS kit might be "affordable" when compared to other FI kits, but it's hardly "cheap."
Old 10-05-2004 | 05:08 PM
Noyzee's Avatar
8 second mod
If i did an sts kit, i would need a tow rig for my tow rig because im an animal! id never stop, im tring not to do anything to the truck, but i just have to!!!!
right now tires are stock, but BFG's are going on and a 3" lift in a couple weeks. then i was going to throw a t-stat and a tune, then i was thinking e-fans, then a set of cheep headers and a retune. i was thinking total with all the about 20 more rwhp would be a good guess. and it would run me about 1500 bucks. (i know a tuner who will tune cheep!!!)
Old 10-05-2004 | 05:12 PM
Scream's Avatar
MOOBIES Moderator
A cam would really wake that truck up! And, it's a lot easier to do a cam swap in a truck than in an F-body FWIW.
Old 10-05-2004 | 05:17 PM
Noyzee's Avatar
8 second mod
I thought about a cam, but its still big $$$$ i have a set of valve springs, but they would be to much for a truck cam, and i have 3 ls1 cams that would be no good in the truck, so by the time i buy cam springs, push rods, im looking at 1000 bucks, then i need to pull it apart, and so on. all for what, about 10-20rwhp? im thinking bolt ons, and if a sponsor wanted to hook me up with an sts kit i would be more then happy to try it out.
Old 10-05-2004 | 05:34 PM
Scream's Avatar
MOOBIES Moderator
You could run the Comp 212/218 low lift w/ some Z06 springs...they go used on here really cheap. You could probably pick one up for $200-250 or less.
I got 31rwhp from this cam in my 4.8 on stock exhaust manifolds. With a tune and headers (and the better heads), I'm sure that it would really wake up that 6.0L.
Old 10-05-2004 | 08:59 PM
8ALTNG's Avatar
noyzee- i would get a cam, headers and have Don at Dez Racing tune it. I believe that he is only like 1hr 15 mins from where you are. Also you could look into having some head work. And i would use any aftermarket parts that are left over from the Z28.
Quick Reply: Need More power!!!!!
