Need more top end what can i do
Tin Foil Hat Wearin' Fool
I got an airaid mit and an ebay intake with a k&n conical saved a couple hundred in the process and only lost a couple of horsepower to other expensive intakes. The cam would be the next step if you are looking for top end. The intake alone is not going to give you that big a difference.
running 6.0 liter with whipple 8 psi 3500 stall servo shift kit ASM long tubes no cats nelson tune 4.10 gears 29.5 m/t 80mm throttle body duel exahsat everything else is stock
