Need oil pump o-ring part #
Im making sure I have all my stuff to get my cam in. I did not think to order a frikkin o-ring for my new oil pump with the rest of my parts. Where I am using an LS6 oil pump is there a different o-ring to use? I cant find the part number for the correct o-ring. Anybody have it??
Originally Posted by 99Silver5.3
Ok, this is what that part # brings up on GMParts.
GM PART # 12563963
CATEGORY: Engine Oil Pump Cover Seal
PACK QTY: 5 CORE CHARGE: $0.00
GM LIST: $4.40
OUR PRICE: $2.51
DESCRIPTION: SEAL
That right?
GM PART # 12563963
GM LIST: $4.40
OUR PRICE: $2.51
DESCRIPTION: SEAL
That right?
Your local Chevy should have all in stock.
You'll need valve cover gaskets....front cover gasket......front crank pulley seal......and you'll also need the oil pick-up tube o-ring if you are planning on changing the timing chain and/or oil pump.
Originally Posted by BenKey
You don't need valve cover gaskets. The valve covers have embedded gaskets.
Originally Posted by 03-25HD
12563963 is o ring for 5.3. LS6 o ring is 12557752.
BmButler,
I have all my parts except for the pump o-ring. I didnt get valve cover gaskets because they can be reused a limited number of times.
Ferocity02
07-17-2015 07:05 PM
